Hej nu kommer det lite nyhetr från Hangar 9 och E-flite, levereras från den 15/7.
Först ut är en Yak:
Specs
Wing Span: 32 in (815mm)
Overall Length: 31.25 in (795mm)
Wing Area: 490 sq in (32 sq dm)
Flying Weight: 10.5-11.5 oz (300-325g)
sedan Mini Ultra stick:
Specs
Wing Span: 38.75 in (985mm)
Overall Length: 34 in (865mm)
Wing Area: 325 sq in (21 sq dm)
Flying Weight: 22 - 25 oz (625 - 710g)
Motor Size: Park 400 Inrunner or Park 450 Outrunner
Från Hangar 9 kommer dessa maskiner:
Mustang Trainer
Progressive design allows smooth advancement to the next level of RC flight
Removable plastic NACA droops for extra stabilization
2-position flaps that can be upgraded to fully functional status
Fixed landing gear and removable speed brake system
Covered in exclusive Hangar 9® UltraCote®
Overview
PTS stands for Progressive Trainer System—groundbreak-ing new technology that allows pilots to progress from learning to fly to performing sport aerobatics without having to upgrade or buy a new airplane. Clear plastic NACA droops attach to the outer edges of the wing, providing beginners with extra stability during training and manipulating the stock airfoil to produce added lift. The fixed landing gear features a special speed brake system that keeps the flying speed down, making the Mustang easy to handle. 2-position flaps add drag, and can be later upgraded to functioning flaps by adding a servo.
Once the pilot has mastered the basics of RC flight, he can quickly and easily remove the droops and speed brakes, instantly transforming the ready-to-fly trainer into a smooth-flying sport plane able to fly a variety of aerobatics such as loops, spins and snap rolls.
Wing Span: 58.25 in
Overall Length: 50 in
Wing Area: 627 sq in (w/droops)
Flying Weight: 6.5-7.0 lbs
Engine Size: .40-.52 2-Stroke
Maskinen kompletteras, med 4 kanals RC utr, motor och start tillbehör, fråga efter paket pris.
Pris: 1 795 :-
Och till sist denna lågvingade buskärra:
Hangar 9 Pulse XT-40, spv 1540mm, motor 46-80, eller Eflite Power 46 outrunner. NYHET
Art Nr HAN4100
Wing Span: 60.7" (1540.5mm)
Overall Length: 50" (1270mm)
Wing Area: 667 sq. in. (43.0 sq. dm)
Flying Weight: Glow engine: 5.5-6.25lbs (2.5-2.8kg) / Electric w/o battery: 4.7-5lbs (2.1-2.3kg) [with battery add approx. 1 lb]
Engine Size: Glow 2-cycle .40-.46, 4-cycle .56-.82 / Electric: E-flite Power 46 Outrunner
Från Simprop kommer denna DS 9 kanaler synth mottagare:
SCAN 9 DS 35MHZ << NYHET>>
Art Nr 0122165
Simprops ny 9 kanalsmottagare
en kraftfull mottagare som har syntez teknologi ( inga kristaller)
Du scannar in din egen sändares frekvens där den sedan låser sig på din sändares kanal.
Direct-Digital-Synthesizer (DDS)
Du kan genom egen kabel programera den på din PC
Vikt 26g
Pris: 1 195 :-
Samma goda prestanda som den omåttligt populära Scan 7 V2.
