Sidan 3 av 3 FörstaFörsta 123
Resultat 41 till 57 av 57
Ämne: Finns det någon som har erfarenhet av en pulsjet ?
  1. #41
    Jakobs avatar
    1 875
    Malmö Radioflygsällskap och Åhus MFK
    Standard Det kom ett brev från Tyskland!
    Igår kom det ett brev från Tyskland med lite info om vad man bör tänka på angående V1 Reichenberg. Jag har nu fått min ritning som jag beställde men nu tvekar jag. Kanske köper jag kitet nämnt nedan i stället.
    Hello Jakob!
    This is Stefan Heuel from Germany.
    I just can say you, that a bavarian named Roland Haug is the owner/pilot of the Pulsejet powered Reichenberg on the pictures.
    And I´m nearly sure that there are no plans available because the model
    has been built for an German museum before a long time. Then Roland bought
    it an made it flyable. That explaines why this model ist so heavy ( 13 Kg)
    Its more a flying stone, than a flying bomb
    But if you are interested in a Reichenberg, I can tell you that a friend of
    mine is building a full scale Reichberg in 1:3,3 in GRP ( I hope that ist
    the correct shortcut )
    I think that it will be ready this year. He also said that he will sale
    kits from it.
    The problem is the weight of the engine. If you look on the leverage of the
    Reichenberg, you will see that a heavy engine will need much trim lead in
    the Front. So the Goal is to use an engine wich is as light as possible.
    In the plan of the Pulso 1 is said that it will reach about 5,5-7 Kp
    Thrust. With my experience I think this thrust wont be reached any way by
    this pulsejet. 4 Kp ist more realistic.
    So the thrust/weight relation is very bad.
    What you need is a High End Pulsjet of the 90mm class. They have around 6
    Kp Thrust but they weight only about 900-1200g.
    So stay tuned.
    Meanwhile you can look around on my Homepage. www.pulsorohr.de
    Video: http://www.pulsorohr.de/Bilder/r500/testlaufr500.avi
    I hope you understand me, my english isnt very good.
    Regards
    Stefan Heuel
    ____________________
    ATT FLYGA ÄR ATT LEVA!
  2. #42
    Hur har det gått med pulsjetprojektet?
    /Håkan
  3. #43
    Jakobs avatar
    1 875
    Jo det går långsamt framåt! Men de främre delarna är klara. Nu ska bara själva röret också tillverkas samt ventilerna!
  4. #44
    Jakobs avatar
    1 875
    Video på linstyrd pulsjet!
    http://www.fesselflug.eu/duse.avi
  5. #45
    tonics avatar
    904
    IT-Tekniker
    Eslövs MFK
    Citat Ursprungligen postat av Magnus
    Nu är den klar! skall bara putsas lite och testas!!
    /Magnus
    Vilken ritning använde du Magnus till din Pulsjet?
    Hur gjorde du med "blomman" (ventilen)?
    Jag och Jakob har alla aluminiumdelar fördiga. Det som återstår är "blomman" och de rostfia delarna.
    Mvh / Toni (tonic) Cederholm.
  6. #46
    jun 2007
    4
    Studerande på JTH
    Hej! Ny på detta forum.
    Verkar intressant med pulsjets! Efter att ha läst lite om det, verkar det relativt enkelt.
    Är det dock inte aktuellt med valveless pulsejets? De verkar mycket enklare att bygga. Men inte lika effektiva.
    Hur går det med era byggen?
    Drömmen är en V1 med pulsjet 1.5m spännvidd!
    Jonathan
  7. #47
    Jakobs avatar
    1 875
    Vi är färdiga med alla aluminiumdelarna så nu återstår endast det rostfria röret samt själva ventilen. Tyvärr har annat kommit emellan men de ska provköras.
  8. #48
    Hunnit med nån provstart?
    /Håkan (nyfiken)
  9. #49
    Jakobs avatar
    1 875
    Nej!
    Men det kommer! Inte högprioriterat för tillfället.
  10. #50
    apr 2007
    29
    Eslövs modellflygklubb
    Har varit inne på att bugga själv men delarna samlar bara damm för att jag gick bet på att skaffa bladfjäderstål 0,150 mm. till ventilerna.
    Har ni månu löst problemet??????
  11. #51
    226
    snart industritekniker
    Södertälje mfk
    hur går det med pulsejetmotorerna?`
    Går bygget framåt?
  12. #52
    Citat Ursprungligen postat av Jakob
    Det går inte att ladda hem filmen. Det står att jag har inte rättigheter till det.
  13. #53
    /Magnus
    Vill du lägga upp bilderna igen. De verkar ha försvunnit.
  14. #54
    Glawes avatar
    feb 2007
    2 171
    Programerare
    Eslövs Flygklubb
    Tog mig friheten att ändra länkarna så att de pekar på rätt adress igen.
    Hoppas det är Ok
    Mvh / Fredrik Glawe.
  15. #55
    Mr Js avatar
    4 159
    Mats Johnsson
    RFK Kometen, Lomma
    Det beror på att vi bytte adress från rcuniverse.se till rcflyg.se.
    Bildlänkarna pekar fortfarande på den gamla adressen...
    /\/\vh // /\/\r J.
  16. #56
    Daniel Ls avatar
    nov 2006
    1 250
    Egen företagare
    mfk pegasus
    varför har ni en sån och inte jag :cry: vill också ha...
    ... ääää vänta lite skolan har ju en komplett plåtverksta med svarv och allt som hör till.
    är det mycket svårt att bygga en pulsjet(sån som ni har med ventiler)???
    har en kompis med en "vanlig" pulsjet utan ventiler och insug så kan nog fråga honom om jag får något enkelt problem.
    och om inte jag klarar av att bygga den har ju alltid skolan 3viggen motorer, en tunnanmotor och ett antal sk60motorer jag kan dregla på
  17. #57
    Blev så tänd av detta så jag slängde ut en tråd på rcuniverse.com, vilket slutade med att jag kom i kontakt med en nisse i norge som ville skänka mig sin maskin, nu väntar jag på spänning när han ska skicka den....
    Allt kan vara bra...
  1. Någon som har erfarenhet av Dragonlink?
    Av Tokaz i forum FPV Radio 35 - 2.4 - LRS
    Svar: 30
    Senaste inlägg: 2014-09-29, 16:27
  2. Någon med erfarenhet av Kalderéns Tummelisa?
    Av Hartmann i forum Skalamodeller
    Senaste inlägg: 2013-04-14, 16:20
  3. Någon med erfarenhet av Kyosho's Hien 50?
    Av ChristerL i forum Metanolmodeller
    Senaste inlägg: 2009-12-29, 16:56
  4. Har någon erfarenhet av denna
    Av puggen i forum Elmodeller
    Senaste inlägg: 2009-11-18, 10:55
  5. Någon som har erfarenhet av Feibao L39 1/7
    Av K-Å i forum Turbin och EDF modeller
    Senaste inlägg: 2007-09-28, 20:59
