Resultat 1 till 20 av 22
Ämne: Jäkla Flatspinn
    wesses avatar
    5 880
    Nykter Alkoholist
    ¤Sunday Team¤
    Unhappy Jäkla Flatspinn
    det vill sig inte riktigt
    Senast redigerat av administrator den 2011-03-25 klockan 11:08.
    Get high with hovering
    not drugs
    Härligt Wesse och Tomten i skogen.
    /Matte
    dom där jäkla flatspinnarna är inte lätta......tror jag ska ta och googla lite se om jag hittar det
    PODs avatar
    749
    Oj..!! Anställd!
    MFK Oskarshamnseskardern
    Träning ger färdighet!! Flatspinnsträning?
    FaR oCH FLyG
    //Ola
    www.oskarshamnseskadern.se
    sm3xrqs avatar
    Sep 2007
    321
    Problemomdirigerare
    MFK looping
    Citat Ursprungligen postat av Google
    The FLAT SPIN is a fairly complex maneuver and should be accomplished by the more advanced pilot. It can be a very nerve racking manuever to learn, so use caution when attempting one or practice with a decent flight simulator before trying it with your favorite plane. To accomplish this manuever, first enter a conventional spin and as the spin developes, SLOWLY add in opposite aileron. As you do this slowly add throttle to about half. The plane *should* flatten out. Now to recover, release the sticks and add opposite rudder and a bit of down elevator. The plane should spin 2-3 more times then fall out. The recovery is where people freeze up and their plane goes BOOM! This is because releasing the sticks doesn't stop the plane from spinning. It won't because one wing panel has completely stalled. Another version of a flat spin is to slowly add down elevator instead of aileron which produces a flatter spin. It also helps to bring the aileron stick to neutral. One tip is to start way up high so you have time to think things out. You can release the sticks to recover but it usually takes anywhere from 5 to 8 turns. It doesn't feel good to see your plane spinning in and hoping it will come out before it goes SPLAT!
    Considder it googled
    Saxat från http://www.scootworks.com/rdrc/aerobat.html
    Har det motor så går det att få det att flyga
    Frågan är bara hur bra
    sm3xrqs avatar
    Sep 2007
    321
    Problemomdirigerare
    MFK looping
    och för att ytterligare svara på ditt inlägg. Flatspin är inte bra...
    Senast redigerat av administrator den 2011-03-25 klockan 11:09.
    2 725
    Här en liten film jag hittat nånstans, minns dock inte var...
    Man ser alla spakrörelser.
    anders es avatar
    Feb 2009
    450
    Smart repair/bilskade tekniker
    Hadeland modellflyklubb (Norge)
    Her har dere flatspinn
    Anders Engesvoll
    Krilles avatar
    1 104
    Slättlanda MFK
    //Kristoffer gustafsson
    Flygplan: Sebart Wind S Pro
    Helikopter: T-rex 700 DFC,
    Sändare: Futaba 14SG,
    4 129
    Vi ses väl på Ripalägret Wesse?
    Då ska du få se på flstspinn...
    wesses avatar
    5 880
    Nykter Alkoholist
    ¤Sunday Team¤
    har prove i stimmulatorn o int fasen blir de någe flatta spinnar där int... får försöka ta mig te ripa för kurs i flatta spinnar..
    not drugs
    gimbos avatar
    Jul 2007
    713
    IT-Proffs
    Lite baktungt hjälper till också.
    Vad är det för plan som Torgny flyger med?
    gimbos avatar
    Jul 2007
    713
    IT-Proffs
    De2 Wesse - Nu är det dags för dig att göra det inverterat. Mycket roligare Så, jag gjorde en video från mitt RealFlight så du får lite att pyssla med. Slängde med en liten snutt av min senaste låt också. Håll till godo
    PS. vet inte om det bara är min webläsare som är knäpp. men kan bara se videon i fullskärm. hmmm
    wesses avatar
    5 880
    Nykter Alkoholist
    ¤Sunday Team¤
    Citat Ursprungligen postat av gimbo Visa inlägg
    Wesse - Snurra som aldrig förr on Vimeo
    kan inte förstå hur du gör Gimbo kan du visa i verkligheten för mig så jag förstår musiken gjorde mig lite okoncentrerad men det lät bra
    planet Torgny flyger är en extra från above all 120cm
    not drugs
    Siguns avatar
    3 959
    En sån här är det väl han har
    http://www.fullkontroll.se/above-ext...592c4920400407
    1395kr
    Finns i denna färgen med
    /Martin
    gimbos avatar
    Jul 2007
    713
    IT-Proffs
    Wesse... Jag kanske kommer till RCFF Shoooootout
    PS. Baktungt ska det vara
    Daniel Ls avatar
    1 252
    Koenigsegg
    mfk pegasus
    vad är det för setup i extran??
    glöm inte bilder och filmer
    Daniel L
    mulders avatar
    1 033
    Hmm måsta lära mig detta med min Jet /Mulder
    Flyger: JET
    Bygger: I Composite
    Motor: Turbin
    Radio: Futaba
    JET SKÅNE
    Jaha...de var en extra. Fint plan tycker jag. Kanske något man skulle investera i framöver då.
  1. Jäkla Träd
    Av DavidFlygare i forum "Publika länkar" Filmer, bilder och annan media
    Svar: 18
    Senaste inlägg: 2010-11-06, 22:26
  2. flatspinn
    Av mds i forum Allmänt och Tips
    Senaste inlägg: 2007-12-14, 09:50
