Resultat 1 till 6 av 6
Ämne: En nybörjar guide till FPV
    Standard En nybörjar guide till FPV
    Jag skrev precis färdigt en nybörjar guide till FPV flygning.
    Den tar bland annat upp vad för egenskaper du ska kolla efter när du väljer flygplan, video sändare, mottagare, kamera och videoglasögon/display.
    Den ger även en liten inblick i de lite mer "avancerade" sakerna som OSDs och diversety controllers.
    Guiden är skriven på engelska och kan hittas på min hemsida.
    Klicka här för att läsa guiden!
    Hoppas någon här kan dra nytta av den.
    Citat från guiden:
    "In this guide I will try and help those of you that want to get started with FPV (First Person View) but don’t know where to start or what to buy. I will try to teach you what to look for and what to look out for when choosing your first components. The guide is segmented into two parts “The basic FPV setup” and the “The “advanced” stuff”. The first part being more in depths, giving basic understanding, and the second part is more of a “carrot” showing ways to enhancing the FPV experience once you got going.
    Introduction
    FPV flying isn’t quite as easy to do as one might think - “It is like learning to fly radio control all over again”. Do not attempt to fly full FPV the first few flights! It’s best to either fly your plane normally (visually) with the FPV gear on it and record the flight so that you afterwards can watch the recording and get used to the FPV point of view, or have a friend fly your plane while you watch the video feed. The important thing is to get used to navigate from the air, which is quite a lot harder than it sounds. A good tip is to before the flight, spot out big landmarks that are easy to see from the air and remember how they are located in relations to your self. You do not want to get disoriented in the air, that will most definitely lead to a crashed or lost airplane. A friend that can visually follow the airplane for you (a “spotter”) and take over if you get disorientated or the video gear malfunctions is a good idea. Take it slow, don’t rush things. It’s easy to loose a FPV airplane.
    Other than that you will need these things to succeed:
    • Skill enough to fly/stear a RC vehicle visually
    • Basic electronics understanding
    • Soldering skills
    • Free time
    • Patience
    • Money
    If you got that were good to go!
    What airplane is suitable for FPV
    To be able to do FPV you need a vehicle of some sort. It can be a car, boat, heli, hovercraft or what ever you want. Since most people that want to do FPV fly airplanes, I will be using that as my starting point to this guide. So what is the best beginner FPV airplane? That is a tricky question since it depends on taste. You first FPV airplane should be:
    • Stable
    • Easy to fly
    • Able to carry extra weight
    • Roomy inside the fuselage
    There are many different airplanes out there that are good for FPV flying, and different people like different airplanes, If I had to recommend an airplane it would be the Multiplex Easy Star. It fulfills all points on the checklist above with ease, it can also take extremely much abuse and it can be modified a lot and still fly great. For these reasons it’s by far the most used FPV plane out there. The Easy Star is also the perfect first airplane for those of you that can’t fly RC yet.
    Here is a link to my Easy Star FPV build log
    Here is a link to my review of the Easy Star"
    www.RCExplorer.se - Blog, tester och guider!
    Mar 2008
    495
    lokförare/magiker
    SRFK,MMFK
    Grymt bra skrivet.. lite länkar i guiden till var man kan köpa lite grejer kan nog få flera intresserade.. bra jobbat
    Tackar, tackar. Hmm kanske ska lägga till en länklista... Tack för feedbacken.
    Siguns avatar
    3 959
    Hej David
    Tack för en utmärkt artikel om FPV. Men hur är det med sändare ? är inte de flesta tillbehören gjorda för Futaba radio? Det är iallafall vad jag förstått hittills.
    Kan kanske vara bra att lägga in en notering om det i artikeln med?
    /Martin
    Mycket Bra skrivet David!!
    Hatten av för nedlagt arbete..o en tydlig "enkel" guide i denna "djungel" av diverse grejer med nya tekniska namn..
    Toppen... /Patrik
    Nexuss avatar
    758
    bra men varför du skrev i engelska text ???
    bör svenska med också
    MVH Steve
    Excell 60 2 St
    Heim 10 CC skala Hughes 500 E
    Concept SR
    Modeltech Cap 21 2 st
    Wonder 2 St
    skaffa:Ace Ultimate, Edge 540
  1. Guide till att förstå "Antenna gain"
    Av dadde i forum FPV Antenner
    Senaste inlägg: 2013-07-07, 12:23
  2. Guide/länk: Fixa enkelt EXPO-funktion på vilken Tx som helst!
    Av markusb i forum Radiostyrning, powerboxar, mottagare, servon, gyro mm
    Senaste inlägg: 2012-07-28, 21:15
  3. Frsky hack MX-16s komplett guide!
    Av bogieboy i forum Radiostyrning, powerboxar, mottagare, servon, gyro mm
    Senaste inlägg: 2011-03-30, 11:25
  4. Vill ha airbrush guide
    Av Zekee i forum Allmänt och Tips
    Senaste inlägg: 2007-01-25, 21:09
  5. Ishkur's guide to electro music
    Av Arvid i forum Diskussioner om vad som helst
    Senaste inlägg: 2006-12-03, 20:47
