Resultat 1 till 2 av 2
Ämne: GO PRO HERO HD nu med TV Out
    Standard GO PRO HERO HD nu med TV Out
    One Button Mode
    One Button Mode simplifies recording video and photos with your HD HERO. With One
    Button Mode, your camera will start recording video or photos automatically when you
    power the camera 'ON' and will only stop recording when you power the camera 'OFF'.
    The shutter button is deactivated in One Button Mode. You can only turn the camera
    on and off, making it the perfect setting for loaning it to friends or newbies.
    Upside Down Mode (UPd)
    Now you can take videos and photos with the camera mounted upside down without
    having to rotate the files later. In UPd, all videos and photos will be saved to
    your SD card right-side up.
    Live Feed Out
    Display live feed SD or HD video and audio straight out of the camera to a TV,
    handheld viewer, or video transmitter. Allows viewing a live video signal during
    preview, recording, and playback of saved files.
    Live Feed On-Screen Display
    Display battery life, camera mode, and recording status icons on your live feed
    video signal with 'On Screen Display' turned on, or turn it off to transmit only the
    video without any status icons.
    PAL 25/50 fps Support
    If you live in a PAL region (most regions outside of North America) you can now
    record in the PAL broadcast standard of 25 / 50 fps in the following resolutions:
    r1 WVGA 50fps
    r2 1280x720 25fps
    r3 1280x720 50fps
    r4 1280x960 25fps
    r5 1920x1080 25fps
    http://www.goprocamera.com/support/hdheroupdate.php
    Äntligen !!!
    Det var f-n på tiden.
  1. Go Pro Hero 3 tips
    Av puggen i forum Allmänt och Tips
    Senaste inlägg: 2013-05-25, 00:07
  2. Hur montera GoPro Hero 3 ?
    Av pernstig i forum FPV Kameror
    Senaste inlägg: 2013-01-22, 16:26
  3. Gopro Hero 1 versus Hero 2
    Av Stiffe i forum Allmänt
    Senaste inlägg: 2012-07-28, 15:17
  4. Gopro HD Hero 2
    Av fpvstockholm i forum FPV Kameror
    Senaste inlägg: 2011-10-24, 13:55
  5. GoPro hero HD
    Av UlfB i forum FPV Kameror
    Svar: 36
    Senaste inlägg: 2011-01-08, 18:33
