Resultat 1 till 1 av 1
Ämne: Pro 70 Motor på Sledgehammer s50
    Kamikazes avatar
    Jan 2007
    505
    Sjöman
    RC-Åland
    Standard Pro 70 Motor på Sledgehammer s50
    Passar Motorn rakt av eller behöver man nytt motorfäste avgaskrök ljudämpare o.s.v ?
    THUNDER TIGER High Performance Car Model Engine Pro-70BK(R) | Pro70BK(R)
    Product Code : [9447 (TT9447)]
    Quality product from Thunder Tiger Corp.
    Introduction
    The Pro-70 was given two modifications: a new carb and a unique starting system. Dropping the Thunder Tiger Pro-70BK(R) engine on your monster truck, makes it not just fast, but to be powerful enough for wheelie.
    Features
    1.Easy built-in starter shaft system
    2.Top grade CNC equipment, state-of-the-art technology are used
    3.Improved three needle carburetor; which makes adjustments simpler
    4.Improved quality; ISO9001 Certified which guarantees the maximum power and performance
    5.Smooth running and long lasting power plant with front and rear ball bearings
    6.Dual-ball bearings, Schnuerle porting, one-ring type piston and cylinder and mixture control carburetor
    7.Designed for both beginners and experienced modelers
    Basic Specification
    [SIZE=""3""] Engine[/SIZE] PRO-70BK(R)
    Displacement 11.49 c.c. / .701 cu.in.
    Bore 25.0 mm / 0.984 in.
    Stroke 23.4 mm / 0.921 in.
    Practical R.P.M. 3,000 ~24,000 rpm
    Output (BHP/RPM) 2.80 / 20,000
    Weight (g/oz) 600 / 21.16
    Senast redigerat av Kamikaze den 2012-03-22 klockan 16:39.
  1. Bra motor?
    Av Thomas i forum Bensinmodeller
    Svar: 21
    Senaste inlägg: 2012-08-24, 21:06
  2. Så gör man en motor!
    Av Pekkala i forum Turbin och EDF modeller
    Senaste inlägg: 2011-09-08, 20:28
  3. RCV 91 CD motor
    Av uffe i forum Förbränningsmotorer
    Svar: 17
    Senaste inlägg: 2009-05-13, 12:09
  4. motor val
    Av mds i forum Elmodeller
    Senaste inlägg: 2007-09-22, 21:30
  5. Motor val i UCD 60
    Av Plura i forum Metanolmodeller
    Senaste inlägg: 2006-12-19, 19:08
