Resultat 1 till 6 av 6
mne: Skysurfer: Hjlp med ny setup fr lngre flygtider (p engelska)
    Standard Skysurfer: Hjlp med ny setup fr lngre flygtider (p engelska)
    (urskta engelskan, postade p rc groups ox...)
    I am trying to equip my SS for longer flight times.
    I have bought the following items to accomplish this:
    1. Hobbywing Pentium 40A ESC
    2. Motor: XYH35-30 1100kv 15A Brushless Outrunner (http://www.giantshark.co.uk/xyh3530-...-p-402740.html). I also have the 1400kv version to use if the 1100 should fail.
    3. 8x4 Prop / 8x6 Prop / 7x6 Prop
    4. Gens Ace 3300 25C 3S Lipo Battery (I also have a couple of 2200 mah to use if too heavy)
    What do you guys think of this setup?
    What Prop do you suggest?
    I am going to have to solder extension cords for the motor leads using 3,5mm bullet connectors, any comments on that (except for keeping them as short as possible I guess).
    I use the CNC motor mount. Is this the correct mounting of the motor?
    Apart from checking the COG after everything has been installed, is there anything else I should do?
    Inlgg
    2 725
    Lite verexponerad bild, ser inte riktigt, drav min frga: proppen sitter vl vnd t rtt hll?
    I vrigt har jag inga svar, men vet att det finns program man kan rkna ut flygtider ungefrligt med.
    I din lnk till motorn finns ju flera som testat med olika proppar,
    det r ju bara att testa med olika proppar och se vad du fr fr flygtider..?
    Ex:
    "Some tests on 3S with different brand props = Prop Amps Watts
    9x6 22 260
    10x6 26 290
    11x4 22 250
    11x6 27 300"
    "I've tried various props but the set up it seems happiest with is as follows; 2250 loong Max 3 cell battery APC style Gcod 10x5 prop. 20 amps at 11 volts = 220 watt"
    Vir prudens non contra ventum mingit
    Citat Ursprungligen postat av jocke1963 Visa inlgg
    Ex:
    9x6 22 260
    10x6 26 290
    11x4 22 250
    11x6 27 300"
    Har testkrt den nya setup:en nu i helgen och det verkar fungera fint med 8x6 prop. Dock fr jag en hel del fludder (vibrationer?) i bilden, som inte youtubes antiskakfunktion kan rda bot p. Kan bero p obalanserad prop, blsten, eller helt enkelt den billiga kameran (keychain cam 808 #16 v2)...
    http://www.youtube.com/watch?v=HAF0EHidko8
    Senast redigerat av Wiciman den 2012-09-25 klockan 09:17.
    Inlgg
    1 583
    Datornrd p heltid
    Mlndals ModellFlyg
    Balansera motor och framfr allt propeller fr att f ordning p frmst fladdrande bild, men du fr ven mindre oljud, bttre livslngd och mer effekt
    Citat Ursprungligen postat av Fluf Visa inlgg
    Thanx, har du ngra praktiska tips/rd hur jag gr till vga, framfrallt gllande balansering av motorn?
    Inlgg
    2 613
    Eslv MFK
    youtube
Liknande mnen
  1. Super SkySurfer 2400mm version av SkySurfer/Bixler
    Av Fluf i forum FPV Flygmodeller
    Svar: 15
    Senaste inlgg: 2012-10-02, 14:28
  2. Flygtider?
    Av zoomzky i forum Allmnt
    Senaste inlgg: 2011-02-21, 19:30
  3. Setup av servo [HJLP SNLLA]
    Av freak174 i forum Elmodeller
    Senaste inlgg: 2010-12-31, 15:34
  4. Behver hjlp med borstls setup!
    Av Toye i forum Elmodeller
    Senaste inlgg: 2010-11-27, 22:27
  5. Nybrjare behver hjlp med el-setup
    Av JohanV i forum Elmodeller
    Senaste inlgg: 2006-07-24, 14:48
Behrigheter fr att posta
  • Du fr inte posta nya mnen
  • Du fr inte posta svar
