Resultat 1 till 3 av 3
Ämne: DeviationTX
    Ernies avatar
    Jan 2013
    59
    Boendestödjare inom psykiatri i Hässelby
    Ingen! men är öppen för förslag
    Standard DeviationTX
    DeviationTX...
Namn:	Devo8s.jpg
Visningar:	131
Storlek:	61,4 KB
    Kanske finns det ett behov av en tråd om Walkera Deviation?
    DEVO 6/6S/8/8S/10
    Devo 7E, Devo 12
    Kopierat från deras hemsida: http://www.deviationtx.com/
    " Deviation is a replacement firmware designed primarily for the Walkera Devo® series RC Transmitters. While Deviation is heavily influenced both by the Walkera DEVO8 firmware as well as by the Flysky/Turnighy based ER9X firmware, it has been written completely from scratch to be easily portable and extensible.
    Major features include:
    Support for multiple protocols without any modifications to the transmitter:
    Walkera Devo 6/7/8/10/12
    Walkera WK2401/WK2601/WK2801
    Nine Eagles J6 Pro (requires telemetry module)
    DSM2
    DSMx (in progress)
    Support for other protocols with very easy transmitter modifications
    Flysky/Turnigy 9X
    Hubsan-X4
    Support for up to 255 different models
    Transmitter can act like a USB drive. Managing models, configuration, icons, and themes is as easy as copying a file...No more need to use the Walkera DfuSe tool.
    Fully configurable themes including bitmaps, fonts, and colors
    Flexible transmitter configuration. Support up-to 12 channels on a Devo8; remap any switches or buttons to any purpose
    All text is localized. Available translations for Hungarian, German, French, Russian, Chinese, Italian, and Romanian. Adding a new translation is as easy as editing a text file, and copying it to the transmitter. "
    Manualen för 8s
    Windows emulator for
    Devo 8 https://skydrive.live.com/redir?resi...D0aIsuAaE9qOU8
    Devo 10 https://skydrive.live.com/redir?resi...H7AOj4fPbeC7mI
    Konfigurera dina inställningar vid datorn och flytta enkelt över via usb.
    Glöm inte att besöka min hemsida: http://helikopter.me
Namn:	gdevention-002.png
Visningar:	138
Storlek:	63,4 KB
Id:	36612   Klicka på bilden för en större version.
Namn:	Devo8s.jpg
Visningar:	120
Storlek:	66,2 KB
    Senast redigerat av Ernie den 2013-02-05 klockan 22:05.
    Bumpar den här tråden. Är vi många här som kör med Deviation? Själv installerade jag programvaran igår och är ruskigt positivt överraskad!
    installerade på min Devo10 och har lagt in alla mina modeller.
    Efter att man suttit och läst i flera timmar om systemet känns det helt ok och jag har redan vant mig vid de nya menyerna.
    skall beställa NRF24L01 modulen så att man kan använda de andra protokollen för andra mottagare.
    Jag har en Devo 7E och är toknöjd med den! Har stoppat i både NRF24L01 och A7105, så jag kan köra nästan allt som deviation har stöd för. Sen igår kväll så gjorde jag range-mod på den (just 7E är gjord för marknader med hårda krav, så den är begränsad till runt 10mW out-of-the-box, men genom att kortsluta en diod så får man full effekt). Lite sugen på att stoppa in fler switchar också...
    Detta flyger jag för tillfället med den:
    - Hubsan H107C/D
    - Hisky HFP80
    - Hisky HCP80
    - Walkera V120D02S
    - Blade 130X
    - Diverse hemmabyggda quads med DSMX-mottagare
    - Simulator!
    Den är liten och smidigt, samt rätt tålig, så jag har den alltid i ryggsäcken, ofta tillsammans med en liten helikopter. Eftersom jag alltid har den med mig, så kan jag dessutom öva lite helikopter i simulator på lunchrasten
