Resultat 1 till 20 av 26
Ämne: Ny version av KK kortet KK2.1 släpt
    Standard Ny version av KK kortet KK2.1 släpt
    http://www.hobbyking.com/hobbyking/s...dproduct=49254
    The next evolution of the rotor revolution is here!! The KK2.1 is packing new found power with updated sensors, memory and header pins.
    Designed by the grandfather of the KK revolution, Rolf R Bakke, exclusively for HobbyKing, the KK2.1 is the evolution of the first generation KK flight control boards. The KK2.1 was engineered from the ground up to bring multi-rotor flight to everyone, not just the experts. The LCD screen and built in software makes install and setup easier than ever. A host of multi-rotor craft types are pre-installed, simply select your craft type, check motor layout/propeller direction, calibrate yourESCs and radio and you’re ready to go! All of which is done with easy to follow on screen prompts!
    The original KK gyro system has been updated to an incredibly sensitive 6050 MPU system making this the most stable KK board ever and allowing for the addition of an auto-level function. At the heart of the KK2.1 is an Atmel Mega644PA 8-bit AVR RISC-based microcontroller with 64k of memory. An additional header has been added for voltage detection, so no need for on-board soldering. A handy piezo buzzer is also included with the board for audio warning when activating and deactivating the board.
    If you’re new to multi-rotor flight or have been unsure about how to setup a KK board then the KK2.1 was built for you. The 6 Pin USBasp AVR programming interface ensures future software updates will be quick and easy.
    Specs
    Size: 50.5mm x 50.5mm x 12mm
    Weight: 21 gram (Inc Piezo buzzer)
    IC: Atmega644 PA
    Gyro/Acc: 6050MPU InvenSense Inc.
    Auto-level: Yes
    Input Voltage: 4.8-6.0V
    AVR interface: standard 6 pin.
    Signal from Receiver: 1520us (5 channels)
    Signal to ESC: 1520us
    Firmware Version: 1.5:
    Pre-installed firmware.
    Dualcopter
    Tricopter
    Y6
    Quadcopter +
    Quadcopter X
    Hexcopter +
    Hexcopter X
    Octocopter +
    Octocopter X
    X8 +
    X8 X
    H8
    H6
    V8
    V6
    Aero 1S Aileron
    Aero 2S Aileron
    Flying Wing
    Singlecopter 2M 2S
    Singlecopter 1M 4S
    (Custom Mix via the "Mixer Editor" option)
    The Mixer Editor allows you to adjust where and how much signal the motors receive from stick input and sensors. This allows you to create any configuration possible with up to 8 motors or servos.
    What is a Multi-Rotor Control board you ask?
    The HobbyKing KK2.1 Multi-Rotor controller is a flight control board for multi-rotor aircraft (Tricopters, Quadcopters, Hexcopters etc). Its purpose is to stabilize the aircraft during flight. To do this it takes the signal from the 6050MPU gyro/acc (roll, pitch and yaw) then passes the signal to the Atmega644PA IC. The Atmega644PA IC unit then processes these signals according the users selected firmware and passes control signals to the installed Electronic Speed Controllers (ESCs). These signals instruct the ESCs to make fine adjustments to the motors rotational speed which in turn stabilizes your multi-rotor craft.
    The HobbyKing KK2.1 Multi-Rotor control board also uses signals from your radio systems receiver (Rx) and passes these signals to the Atmega644PA IC via the aileron, elevator, throttle and rudder inputs. Once this information has been processed the IC will send varying signals to the ESCs which in turn adjust the rotational speed of each motor to induce controlled flight (up, down, backwards, forwards, left, right, yaw).
    *Royalties paid on each unit sold to Rolf R Bakke, the original KK Designer.
    ** Note: An updated software version”1.6” for the KK2.1 is available. It is all ways recommended to update to the latest software version as part of your initial setup.(this is different than v1.6 for 2.0)
    PRODUCT ID: 9171000334-0
    40g OK Buy 1 Buy 2 $29.99
    Standard Ny version av KK kortet KK2.1 släppt
    Jo detta har jag läst på HK websida men vad betyder det praktiskt?
    Är det någon som kan beskriva lite enkelt vad fördelarna är med KK2.1 jämfört med KK2.0 ?
    /Lars
    Jun 2013
    362
    Grafiker
    Hökaklubben - Halmstad
    De nya processorn och gyrona är nog minst dubbelt så snabba och kommer bidra till betydligt stabilare flygning. Samma som CC3D och MultiWii kör t.ex.
    1 583
    Bättre gyro/processor, pins för voltage alarm och firmware 1.5 förinstallerat är skillnaden mot 2.0
    3 898
    Om inte jag minns fel så sitter det mpu6000 i cc3d men nästan samma.
    Jag tror inte processorn är snabbare utan bara mer minne, och några andra små förändringar.
    sen är jag skeptisk till att en atmel processor kan leverera lika bra som en stm processor men den ser ju lovande ut helt klart.
    Har inga specar här nu men tror cc3d's processor är mer än 4ggr så snabb som atmegan.
    Jun 2013
    362
    Grafiker
    aha det var alexmos-kortet jag lekte med igår som hade 6050 hehe. aja close enough, bara en siffra fel
    3 898
    tror inte det är några enorma skillnader på dom
    Fredrik_Ws avatar
    Apr 2012
    258
    Ja, Stockholm
    MMFK
    Det är väl antagligen sant eftersom de har döpt kortet från 2.0 till 2.1 och inte 2.0 till 3.0
    // Fredrik W
    3 898
    Tänkte mest på gyrot, men stämmer nog i övrigt också.
    men man vet ju inte vilka versionsstandarder dom kör med för mig är det "minor change" som siffra 2 förändring står för.
    Tydligen så finns det en åtkomlig databuss som medger inkoppling av externa komponenter
    Citat Ursprungligen postat av joakim_s Visa inlägg
    tydligen så finns det en åtkomlig databuss som medger inkoppling av externa komponenter
    gps? =)
    Fredrik_Ws avatar
    Apr 2012
    258
    Ja, Stockholm
    MMFK
    Någon som vet vad man behöver för gadget för att uppdatera mjukvaran? Jag kunde inte hitta någon lämplig pryl under relaterade produkter?
    // Fredrik W
    3 898
    Samma som tidigare om inte jag minns fel , en usbasp som mer eller mindre konstant är restad hos hk
    Sep 2013
    286
    Electromekaniker på Renault.
    Ingen ännu.
    simonarvestrand: Är det en sådan här som behövs?
    http://hobbyking.com/hobbyking/store...rSearch=usbasp
    Det ser ut som om dom fått in nya nu i Europa lagret.
    3 898
    Citat Ursprungligen postat av SA3BGM Visa inlägg
    Precis , en sån borde alla äga , perfekt för fwuppdateringar på diverse atmelbaserade prylar.
    Vad använder ni för quad till kk kortet?
    Dels en hobbyking dji 450 kopia f450 och rcflights disco liknande farkost som heter reptile 500..
    3 898
    Mååånga olika , allt från några plåtbitar och träarmar till dji450 funkar till det mesta
    Är detta den bästa budget lösningen då? såg att det fanns en liknande Naza för 50USD dock utan GPS då.
    3 898
    vad har du hittat för nazapryl som är så billig ?
    kk2 är en riktigt bra budgetlösning, går givetvis inte jämföra riktigt med dyrare prylar men för den pengen är det riktigt bra
