Resultat 1 till 5 av 5
Ämne: HobbyKings grundlista el flyg
    teamleaders avatar
    Jan 2013
    255
    16
    Arbetslös se presentationsblogg.
    F.n ingen alls men funderar på medlemskap i KMFK eller AKMG.
    Standard HobbyKings grundlista el flyg
    Här är Hobbykings grundregler för elflyg. Läs speciellt nedersta stycket som handlar om ESC och det beskrivs att om en motor är testad och godkänd för 40A ESC så bör man välja en ESC som är 20-25% högre än motorns rating dvs ESC:n ska vara kanske 45-55A på en 40 ESC motor och givetvis ju högre desto bättre. Här beskrivs också LiPo accar samt KV och NTM tabeller, så vem ska jag lita på eller är allt detta bara påhittat av Hobbyking?
    An under-powered model is a disaster waiting to happen, here is a rough guide to choosing the electric power train needed for various model types, bear in mind that over-powering is fine but the penalty is additional weight, and a good model is one that is balanced in terms of power, flying weight and build quality. This guide is as the title says, a ROUGH guide and offers a basis from which to choose a power train for your model, it is not intended to be a definative guide but will help to get you into the air with performance that will make your introduction to electric flight enjoyable and reliable.
    MOTOR POWER CHOICE(base on reccomended AUW, or Flying Weight of model choice):
    Vintage types and many non-aerobatic indoor flyers - 50w~70w per 1lb
    Trainers, gliders and high wing scale - 70w~100w per 1lb
    Sport flyer with general aerobatic performance - 100w per 1lb
    Warbirds - 120w~150w per 1lb
    Multi engined models - 100w per 1lb (thrust from Multiple props gives in effect, more than 100w per 1lb performance)
    EDF Jets - 150w~200w per 1lb
    3D, F3A and high performance Models - 150w~200w per 1lb
    LIPOLY VOLTAGE CHOICE
    Based on the above, we now need to work out what voltage we are going to need to use, generally, to keep Lipo's in good order, try and keep max amps to around 50~60% of the capacity/C rating of the Lipoly Pack, for example, if you purchase a 2200mAh 20c pack, then it is rated for 44A constant discharge, so keep the max amps at around 20A~25A IF possible, it isn't always! Choose the capacity of pack based on reccomendation for the model by model manufacturer and in conjunction with the size/weight data published with all our advertised Lipoly packs, for low powered models, choose 20c packs, for general flying choose 20c~25c packs, for high performance models 30c + packs;
    Up to 50w: 1s~2s
    up to 100w: 2s~3s
    100w Up to 500w: 3s (This is the practical upper limit for 3s Lipo's, so basically, models of 5lb AUW)
    500w up to 800w: 4s (This is the 0.40~0.46 glow equivalent range favoured by many club flyers)
    800w up to 1000w: 5s
    900w up to 1500w: 6s (this is the 0.60~0.90 ic equivalent range)
    8s~10s packs are for very large and generally specialised models.
    MOTOR CHOICE - KV or RPM per volt
    Which actually means, what prop size! If you are used to IC, the simple analogy is to treat low kv motors as 4 stroke engine equivalents and mid-high kv motors as 2 stroke engine equivalents, if you are not used to IC then we can give you some examples of the approach to take, this is an important choice as you can literally choose how your model flies, however, their are practical considerations, the most obvious is ground clearance. Please refer to motors such as the NTM range, which give you prop data as well as power, dimension and weight data.
    Example 1: Trainer/Sport Model, 1lb AUW, we want 100w motor (3s 20c Lipoly) mid kv for general flying, probably around 1200kv~1400kv, so around 8" prop
    Example2: 3D/F3A Model, 1lb AUW, we want 150w motor (3s 20c~30c Lipoly) low kv, 1000kv or under, spinning 10~11" prop, highly efficient at low throttle openings giving lot's of prop wash over control surfaces at all times, high thrust for low rpm and low amps draw at higher throttle openings.
    Example 3: Warbird/scale Model, 1lb AUW 120w motor, kv choice, either of the above, it is personal choice
    Example 4: High Speed Delta type model, 1lb AUW, 200w motor (3s 25c~30c Lipoly) 2200kv~3200kv motor, 5"~6" Prop, high speed/low torque, low thrust at low throttle openings, high speed from high rpm at full throttle.
    FINALLY, ESC CHOICE
    You have decided on your motor, so look at the MAX AMPS figure given by the motor manufacturer in the data section and generally add 25% headroom, so, if a motor is rated to 15A, then choose at least an 18A ESC, better still a 20A and so on. Next make sure that the ESC voltage is compatible, in other words, if you are using a 4s Lipo, that the ESC is rated for 4s voltage. Next, check if it has functions you desire, if you are flying a glider for instance, you will want a brake facillity so that the prop stops when soaring un-powered, allowing the prop to fold by not windmilling, we strongly advise purchasing a programme card to make programming the ESC easier. Also look at BEC rating, the BEC supplies radio reciever power for servo's without the need for a seperate reciever battery, however, the can be limited in the number of servo's they are capable of powering, if the servo count is over 4, as it is on many models these days, then consider purchasing an ESC with a high AMP rated SBEC, or a seperate UBEC, OPTO type ESC's (they have no BEC, keeping the ESC seperate from RX suply) are reccomended for large models that require a seperate reciever power supply, they are also safer in high powered, large models as they will not arm until the RX is switched on.
    Kom inte och påstå att jag skiter i att skaffa mig kunskap om grejorna jag beställer.
    Senast redigerat av teamleader den 2014-05-07 klockan 14:37.
    Mathias, simulatortränad.
    Men om du tvivlar på vad folk säger eller rekommenderar så varför fortsätter du fråga? Om du tycker att det står solklart på HK s sida kör på det då.. folk här säger vad de tycker och va de har kommit fram till under sin tid i hobbyn..
    Skywalker 1900
    Bixler 2
    Quads i lite olika storlekar
    3 871
    Att ta i i överkant på esc och tänka på vad motorn kan leverera på tillex en quad som kanske aldrig kommer flygas på över 80% av vad motorn kan ge är i min värld idiotiskt.
    En liten tanke med en företag som Hobbyking kan också vara att dom vill tjäna pengar dom får dig till att köpa dyrare saker som dom säkert tjänar mer på fast du inte behöver. skulle aldrig i livet lita på en sådan nätbutik och följa deras råd.
    Du har ju ett av dom bästa ställena att få information på här varför harva runt på nätet, lita på folket vi har några av världens duktigaste modellflyg folk i sverige folk som är kända över hela världen.
    Apr 2014
    1 024
    Maskin förare
    Dendär guiden är ju inte verklighets förankrad. för det första är det om flygplan. Det är bara en snabb guide dessutom och går inte in på djupet någonstanns.
    Det med ratingen... kan man tolka det så här: HobbyKing vet att noggrannheten på deras grejer är sisådär så därför bör köparen köpa lite hävare grejer så man inte får problem. Därav välja grejer med högre marginal än vad som ska vara nödvändigt. =)
    Det finns så mycket skräp i dag så när jag vill bygga nåt och inte tar mig tiden att lära mig allt (läsa) eller köpa och testa vilket skulle ge mig enormt mycket mer kunskap... så frågar jag istället på detta forum. Får väldigt sällan tips på att köpa nåt från tex HobbyKing. Två pers kan säga att en ESC är underbar och en annan berättar sin version om hur skit de är. Sen brukar det rulla på och efter ett tag så har man bättre koll på vad det är man egentligen borde köpa. =)
