Resultat 21 till 40 av 46
Ämne: Vinterprojekt - ver 2.0...
    6 149
    Stabilatorn inpassad!!
    Länksystem återstår...
Namn:	20150225_213848.jpg
Visningar:	156
Storlek:	99,5 KB
    Hi Thomas, hi everyone, my name is Vincent, 51 old, I live in the south of the France. I'm the webmaster of the website/forum Retroplane.
    I built the Mira3, you gave the link in this thread. I love the Mira with an incredible look, and this glider fly very well.
    Thomas, congratulation for this choice, I'm happy to follow your building. If I can help you, don't hesitate.
    What scale/size did you build it?
    6 149
    Hi Vincent!
    Or Bonjour, monsieur!
    I like very much odd and unusual planes, not the everyday Cubs, Extras, Sukojs etc.
    When I was surfing around on Internet searching for my next project, I discovered the "Mira3", and found it so odd I would like to build it!
    The ´plan´ is a A4-copy of the plan on Retroplane´s webpage.
    I don´t know the exactly scale propotions, but the wing span is approx. 160 cm.
    I don´t have the intention to build the plane as a true scale glider, it will be motorized, probably with an electric motor.
    It is not in exact scale, I just like the outlines...
    Where will you install the motor? between the wings on a pylon?
    you can make a scale pylon with fake cylinders, like here
    http://www.retroplane.net/forum/view...=asc&start=225
    6 149
    La belle dame posant!
Namn:	20150228_171539.jpg
Visningar:	129
Storlek:	87,2 KB
Id:	50901 Klicka på bilden för en större version.
Namn:	20150228_171659.jpg
Visningar:	131
Storlek:	82,6 KB
    I'll figure out some kind of pod for the motor.
    The propeller will probably 'hang out' in front of the cockpit...
    6 149
    Provar in en motor-pod.
    Lite uppåtriktning ska nog kompensera för den höga motorplaceringen, som i så fall skulle 'dra ner' kärran vid motorpådrag.
    Så resonerar jag...
Namn:	20150305_203801.jpg
Visningar:	304
Storlek:	88,7 KB
Id:	51028 Klicka på bilden för en större version.
Namn:	20150305_203818.jpg
Visningar:	153
Storlek:	73,2 KB
    Btw, är det nån som säljer LÄTTA stora antikhjul som dom på bilden?
    Ca 110-120 mm diameter.
    Dom som sitter där nu är så jäkla tunga!
    LIPs avatar
    1 299
    Örnsköldsviks modellflygklubb
    Så resonerar jag...
Visningar:	304
Storlek:	88,7 KB
Visningar:	153
Storlek:	73,2 KB
    Det blir en "frän" modell!
    /Lasse
    Modellflygare sedan 1952
    3 931
    Skorstensfejaringenjör
    Du har verkligen en förmåga att hitta lite....udda...men härliga...förebilder!
    6 149
    Ja va f*n Göran, hur många Cubbar går det på ett dussin? Egentligen???
    3 931
    Jag skulle nog kunna gissa på en 18-20 Cubbar på ett dussin.
    I don't know if Google translator is right, but if you find your wheels too heavy you can make them in balsa/plywood like mine, it's lightest.
    You can keep the rubber tires from your plastic's wheels and make them without fake spokes. Detail here http://www.retroplane.net/triplan-clement/page1.htm
    6 149
    Liiite segt på byggfronten, men Myran har i alla fall fått på lite kläder...
Namn:	20150421_215926.jpg
Visningar:	124
Storlek:	144,6 KB
Id:	51944 Klicka på bilden för en större version.
Namn:	20150421_215959.jpg
Visningar:	134
Storlek:	123,8 KB
    Skevroderservoinstallation härnäst!
    6 149
    Jahapp!
    Ett par sidorutor och en lämplig pilot, sen kan 'Flügmyran' kanske komma i luften.
    Vikten just nu är 1200 gram, men det behövs nåt hekto till i nosen....
Namn:	IMG_6883.jpg
Visningar:	142
Storlek:	149,9 KB
Id:	52121 Klicka på bilden för en större version.
Namn:	IMG_6885.jpg
Visningar:	119
Storlek:	138,3 KB
Id:	52122 Klicka på bilden för en större version.
Namn:	IMG_6886.jpg
Visningar:	117
Storlek:	122,1 KB
Id:	52123 Klicka på bilden för en större version.
Namn:	IMG_6888.jpg
Visningar:	111
Storlek:	169,8 KB
    LIPs avatar
    1 299
    Den såg ju kul ut och den flyger säkert bra.
    /Lasse
  15. #35
    karstenas avatar
    Oct 2012
    370
    Næringsmidelarbejder
    hangar4800-
    den ser rigtig fed ut. Fedt at der stadig er nogen som har fingersnille. Bra gået Thomas.
  16. #36
    Du e för go Thomas, med dina underbara udda bygge. Till på köpet så flyger dom med.
    Ser fram emot premiären.
    Med vänlig hälsning Robban
  17. #37
    6 149
    Tack Robban!
    Men du missade premiären idag...!
    Flög som en skadeskjuten kråka!
    Kan det ha berott på att byggherren hade lyckats få in ett par bitar med skevt bandyklubbevirke i vänstra vinghalvan??
    Jag ska ta ett allvarligt snack med honom om noggrannheten i byggandet...
    6 149
    Hemsk musik, förresten, det var det enda slaviska jag hittade i hastigheten.
    (Kärran lär vara tjeckisk, eller nåt....)
    2 725
    Snygg!
    Men såg lite baktungt ut, upplevdes hon så?
  20. #40
    4 119
    Huga! Så störig musik!
    Den kan ju inte vara helt lätt, den där ser inte ut att ha en rät vinkel ens på samma flygfält...
