Hi Thomas, hi everyone, my name is Vincent, 51 old, I live in the south of the France. I'm the webmaster of the website/forum Retroplane.
I built the Mira3, you gave the link in this thread. I love the Mira with an incredible look, and this glider fly very well.
Thomas, congratulation for this choice, I'm happy to follow your building. If I can help you, don't hesitate.
What scale/size did you build it?
Hi Vincent!
Or Bonjour, monsieur!
I like very much odd and unusual planes, not the everyday Cubs, Extras, Sukojs etc.
When I was surfing around on Internet searching for my next project, I discovered the "Mira3", and found it so odd I would like to build it!
The ´plan´ is a A4-copy of the plan on Retroplane´s webpage.
I don´t know the exactly scale propotions, but the wing span is approx. 160 cm.
I don´t have the intention to build the plane as a true scale glider, it will be motorized, probably with an electric motor.
It is not in exact scale, I just like the outlines...
Where will you install the motor? between the wings on a pylon?
you can make a scale pylon with fake cylinders, like here
http://www.retroplane.net/forum/view...=asc&start=225
Provar in en motor-pod.
Lite uppåtriktning ska nog kompensera för den höga motorplaceringen, som i så fall skulle 'dra ner' kärran vid motorpådrag.
Så resonerar jag...
Btw, är det nån som säljer LÄTTA stora antikhjul som dom på bilden?
Ca 110-120 mm diameter.
Dom som sitter där nu är så jäkla tunga!
Du har verkligen en förmåga att hitta lite....udda...men härliga...förebilder!
Ja va f*n Göran, hur många Cubbar går det på ett dussin? Egentligen???
I don't know if Google translator is right, but if you find your wheels too heavy you can make them in balsa/plywood like mine, it's lightest.
You can keep the rubber tires from your plastic's wheels and make them without fake spokes. Detail here http://www.retroplane.net/triplan-clement/page1.htm
Den såg ju kul ut och den flyger säkert bra.
/Lasse
Modellflygare sedan 1952
den ser rigtig fed ut. Fedt at der stadig er nogen som har fingersnille. Bra gået Thomas.
Du e för go Thomas, med dina underbara udda bygge. Till på köpet så flyger dom med.
Ser fram emot premiären.
Med vänlig hälsning Robban
Tack Robban!
Men du missade premiären idag...!
Flög som en skadeskjuten kråka!
Kan det ha berott på att byggherren hade lyckats få in ett par bitar med skevt bandyklubbevirke i vänstra vinghalvan??
Jag ska ta ett allvarligt snack med honom om noggrannheten i byggandet...
Hemsk musik, förresten, det var det enda slaviska jag hittade i hastigheten.
(Kärran lär vara tjeckisk, eller nåt....)
Snygg!
Men såg lite baktungt ut, upplevdes hon så?
Huga! Så störig musik!
Den kan ju inte vara helt lätt, den där ser inte ut att ha en rät vinkel ens på samma flygfält...
/\/\vh // /\/\r J.
