Resultat 1 till 5 av 5
Ämne: Taranis X9E släppt?
    1 581
    Standard Taranis X9E släppt?
    http://www.hobbyking.com/hobbyking/s...arehouse_.html
Namn:	87929(4).jpg
Visningar:	102
Storlek:	34,0 KB
Id:	57775Klicka på bilden för en större version.
Namn:	87929s1(4).jpg
Visningar:	98
Storlek:	51,0 KB
Id:	57776Klicka på bilden för en större version.
Namn:	87929s(4).jpg
Visningar:	91
Storlek:	29,3 KB
Id:	57777Klicka på bilden för en större version.
Namn:	87929s2(4).jpg
Visningar:	108
Storlek:	45,0 KB
    Dök precis upp på US East hos Hobbyking för 269,99$ Låter billigt för vad det är.
    Lite sugen är man.
    With a slightly retro, cool look and feel, the FrSky Taranis X9E or "Tray" Taranis is very closely related to the enormously popular and wholly reliable Taranis Plus (X9D).
    This is a 16 channel radio (expandable to 32) and has all the features we have come to expect from a Taranis transmitter including full telemetry, speech, channel mixing, different flight modes, multiple model memory, the list goes on and of course the amazing OpenTX firmware, which has been optimised, remains the heart of the machine.
    The X9E comes with improved gimbals and a daylight readable LED screen at the top to display telemetry data. There is also Bluetooth connectivity for data transfer.
    Once again FrSky have put together a premium quality radio control transmitter and have delivered it for a fraction of the cost of similar products on the market.
    Features:
    • Metal front panel
    • Upper and lower information screens
    • 6 potentiometers and 8 switches
    • 2 potentiometer slots ansd 8 switch slots for extension
    • 16 chanels/ up to 32 channels
    • Two module two frequency system
    • Receiver lock
    • Low latency and high precision
    • Full telemetry
    • Real time flight data logging
    • Quad Ball Bearing Gimbals
    • Receiver Match
    • Audio Speech Outputs (values, alarms, settings, etc.)
    • Antenna Status Detection and Adjustment
    • Receiver Signal Strength Indicator (RSSI) Alerts
    • Smart Port Supported
    • Vibration Alerts
    • Removeable hand rests
    Specs:
    Compatibility: FrSky X series, D series and V8-II series receivers (plus other receivers if an external module is used)
    Model:Taranis X9E
    Operating Voltage Range: 6~15V (2S, 3S Lipos are acceptable)
    Operating Current: 260mA maximum (both RF module and backlit are on)
    Number of Channels: 16 Channels (extensible to 32 channels)
    Operating Temperature Range: -10~60C
    Included:
    1 X Taranis X9E Transmitter
    1 X X6R Receiver
    1 X Neck Strap
    1 X Carry Case
    1 X 9.6V MiMH 2000maH Battery
    1 X Charger (US Plug)
    1 X SD Card
    7 109
    Fast X9E har ju funnits att köpa länge...Kompisen hade en i alla fall i somras. Avser du att den är ny i HK's sortiment eller ?
    Aug 2014
    69
    Design engineer - Saab AB
    Norrköpings Radioflygklubb
    tror du blandar ihop den med X12S som inte släppts ännu..
    /Philip Thulin
    1 581
    Ja, my bad, blandat ihop med X12S. LOL
    3 208
    Lunds Radioflygklubb
    Nu i dagarna släpps en Betaversion av X12S. Den saknar dock GPS. Den distribueras till utvalda FrSky-användare som ska utvärdera och ge kritik och omdömen på sändaren.
    Fabriken kommer sedan att implementera de förslag och ändringar som leder fram till den slutgiltiga versionen som sedan släpps ut på marknaden.
    Tyvärr - som FrSky brukar - kommer det att dröja ytterligare några månader innan den blir tillgänglig på marknaden.
    Jag har tecknat mig för ett par stycken "Betasändare" som några svenska brukare får testa.
    Ove (AM) Nielsen
