Namn:	image.jpg
Visningar:	25
Storlek:	51,6 KB
Turnigy Aerodrive SK3 2822 1090kv Borstlös Motor
Turnigy Aerodrive SK3 2822 1090kv Brushless Outrunner Motor. Borstlös motor. Lämplig för mindre RC flygplan typ slowflyers och parkflyers. Motorn motsvarar Hacker A-serien. Helt ny i kartong.
Annonsen finns på Tradera:
Turnigy SK3 Motors are the next leap forward in motor quality and design. We instructed the engineers to source the best quality magnets, bearings and materials available to them and develop a motor that would not only rival, but surpass the quality of many leading motor manufactures on the market today. The result is an efficient, high caliber motor using quality double shielded bearings, sintered Neodymium magnets and a string wound stator ensuring an accurate and consistent winding each and every time. The Turnigy SK3 motors are suited to modelers who are seeking a quality brushless motor without compromise.
Turns: 50T
Voltage: 2~3S Lipoly
RPM/V: 1090kv
Internal resistance: 0.235 Ohm
Max Loading: 7A
Max Power: 80W
Shaft Dia: 3.0mm
Bolt holes: 16mm & 19mm
Bolt thread: M3
Weight: 31g
Motor Plug: 3.5mm Bullet Connector
