Resultat 1 till 2 av 2
Ämne: ImmersionRC Vortex 150 (1-600mW) BNF FrSky
    Standard ImmersionRC Vortex 150 (1-600mW) BNF FrSky
    Säljer en helt ny ImmersionRC Vortex 150 quad.
    Endast uppackad för montering av FrSky XSR (non-EU firmware) mottagare (monterad inuti quaden) samt ditsättning av skids från Vortexskids (se bilder).
    Flashad med senaste FW från ImmersionRC (Betaflight 3.1.6).
    Detta är den internationella versionen med VTX som klarar upp till 600mW.
    Features:
    • Fusion of 3k weave Carbon Fiber and tough molded plastic
    • Synergy Flight Controller (Cleanflight / Betaflight)
    • Twin ‘F3’ Processors (Flight Control, and OSD) (CPU STM32F373 32-bit ARM processor)
    • 1306-3100kv motors
    • 3rd Gen 16A EzESCs, With OneShot125/42 support
    • Direct connection to PPM, Spektrum, S-Bus, XBus receivers
    • Integrated full-graphic OSD, with on-screen control of.... Everything
    • DSMX Video Transmitter Control with Dynamic Power Control
    • Integrated Touch’n’Race system (TNR Race Wand sold separately)
    • Integrated Leading-edge 5.8GHz 40Ch Video Tx
    • 500mAh~750mAh 4S battery recommended
    • Sub 250g configuration with 500mAh pack
    • Each Vortex 150 Mini is tested before leaving factory
    • LED Board integrated into PDB (XT30 Connecter)
    • Lost Model Beeper
    • Internal Rx installation
    Specs:
    Wheelbase: 155mm
    Arms: 2mm Flat CF/Plastic Hybrid
    Weight: <250g w/500mAh 4S pack
    Frame: 2mm CF, with Aluminium Standoffs
    Motors: Vortex 1306-3100kv, 2mm Shaft
    ESC: 16/20A EzESC Gen3
    ESC Features: OneShot125, OneShot42, MultiShot, rotorSENSE
    Props: 3030 3? Tri-Blades
    Gyro: SPI Gyro, for 8kHz loop speeds
    Microphone: Integrated
    Flight Camera: FatShark 600TVL CCD (HS1177 sensor + chipset)
    Video Tx Power: 1mW - >600mW variable
    Pit Mode: Full Support
    Glitch Free Channel Change: Full Support
    Rx Support: Native CPPM, S-Bus, Spektrum, XBus, SumD, SumH
    Rx Selection: Fully Automatic
    Internal Rx Support: SPM9645 (DSMX), SPM4648 (DSMX). XSR (FrSky), X4R-SB (FrSky, depinned)
    Included:
    1 x ImmersionRC Vortex 150 Mini Racing Quadcopter
    1 x FrSky XSR Receiver
    4 x 3030 3-Blade Propellers (Spare)
    1 x Cable Set
    1 x Manual
    Pris: 2400:-
    Pris utan FrSky XSR mottagare: 2200:-
    Nypris utan mottagare: 3295:-
    http://www.autopartner.se/multicopte...150-eu-edition
    Skicka PM vid intresse!
    Senast redigerat av Nfinite den igår klockan 20:33.
    Multirotor: DJI Inspire 1 v2.0, Vortex 250 Pro, Vortex 150 Pro
    Radio: Taranis X9D+
    Nya priser!
    Radio: Taranis X9D+
Bokmärken
Bokmärken
