Laddaren är helt i nyskick och endast testad.
EV-Peak E6 Intelligent Charger (LiPo and LiHV Batteries) (EU Plug)
The EV-Peak E6 Intelligent Battery Charger specializes in
charging small one cell LiPo and LiHV batteries. This is great for all
your micro-aircraft, drones and small RC cars. It can charge 4
individual batteries at the same time, which allows batteries to be
charged more quickly.
This charger is easy to use and has an LCD screen to allow for
intuitive setup of each charging connection. The charger supports
JST/Molex/MCPX/MCX connectors allowing a variety of batteries to be
charged. It comes with a built in AC power supply but can also be used
at the local field from your car battery as it has a 9~12V DC input as
well. There is built in short circuit, over current and over temperature
protection making the charger safer and more reliable.
Get yours now and get charging all those small, one cell batteries on the go.
Features:
• 4 x 1 Cell LiPo/LiHV Battery Charger with JST/Molex/MCPX/MCX connectors
• Using four-channels for fast charging, four different batteries at the same time
• Using LCD display, intuitive display battery charging voltage and current for single channel
• AC and DC dual input
• AC input 100~240V for worldwide use
• Plug and play for easy operation
• Short circuit, over current and over temperature protection, safer and more reliable
Specs:
AC input voltage: 100~240V AC
DC input voltage: 9~12V
Charge current: 0.1~1.0A x 4 channels
Charge power: 4.35W x 4 channels
Battery type: LiPo/LiHV
Battery socket: Molex, BEC, MCPX, MCX
Charge indicator: LCD display and LED indicator light
Charge output: 4 independent outputs
Dimension (LxWxH): 120x120x51mm
Weight: 500g
Package includes:
1 x EV-Peak e6 Smart Charger
1 x Power cable
1 x Alligator clips
Pris: 199:-
Skicka PM vid intresse!
