Helt ny oanvänd!
OrangeRx R620X V2 6Ch 2.4GHz DSM2/DSMX Comp Full Range Rx w/Sat, Div Ant, F/Safe & CPPM mottagare.
Features: (R620X V2 CPPM)
• Compatible with DSM2/DSMX 1024/2048 aircraft radio and module systems
• True diversity long antennas that can be placed in convenient locations in the aircraft
• Easily replaceable antennae using u.Fl connectors (not soldered)
• Ultra-fast brownout recovery and programmed fail safe mode
• Wide input voltage: 3.7~9.6V
• 6 Channels PWM
• 9 channels cPPM
• Extremely long range: Control - 2 Km or more (LOS), Telemetry - 400m or more (LOS)
• Integrated telemetry for real time readings: Temperature, Battery Voltage, Receiver pack Voltage, Motor RPM, Current
• If required, integrated telemetry function can be disabled during binding.
Specs: (R620X V2 cPPM)
Channels: 6 PWM 9 cPPM
Input voltage: 3.7~9.6V
Current: 55mA
Range:<2Km
Telemetry range: <400m
Dimensions: 49 x 22 x 15.5mm
Weight: 12.2g
Included:
OrangeRx R620X V2 CPPM 6Ch 2.4GHz DSM2/DSMX Compatible Full Range Receiver
Bind plug
Pris: 199kr
Skicka PM vid intresse!
Namn:	IMG_20200909_101727.jpg
Visningar:	86
Storlek:	30,5 KB
Id:	71596Klicka på bilden för en större version.
Namn:	IMG_20200909_101739.jpg
Visningar:	81
Storlek:	24,5 KB
