1/10 Crawler Chassi 4WD - AUSTAR 313mm Wheelbase Chassis Frame
Helt nytt AUSTAR 313mm Chassi med däck och motor, kan jämnföras med SCX10 II då det ser ungefär likadant ut.
Perfekt chassi att börja med om man vill testa Crawling och komma igång billigt.
Sök på Youtube eller google efter Austar SCX10 II så finns det flera byggfilmer och reviews.
Mer Info:
This RC car chassis set is similar designed like the 1/10 SCX10 II RC car.
This set comes with a 313mm wheelbase chassis with a 540 motor and a built-in derailleur and a front bumper.
The excellent texture, best reliability and hardened steel construction render the chassis popular among the RC hobbyists, which must be the best choice of you as well.
Features:
With 540 35T brushed motor, which built in precision balanced rotor to achieve smoothness for best reliability and stronger power.
Built-in derailleur which is sensitive in power distribution achieves smooth vehicles starting.
Hardened steel construction including injection molded nylon axle housing, metal internal gears, drive shaft, metal shock absorbers and metal frame girder allows it durable in use.
Amazing design with a low center of gravity provides a stable driving for your RC crawler.
Strong steel chassis produces optimal balance between weight and strength.
High driving efficiency, compact structure, convenient assembly.
Any problem, please contact our store without hesitation. Honor to serve you.
Specifications:
Brand: AUSTAR
Model: AX-8501
Color: Black
Quantity: 1 Set
Material:
Frame Rails Material: Steel
Axle Shell Material: Reinforced Nylon
Gear & Shaft Material: Metal
Gearbox: Reinforced Nylon
Drive Shaft: Metal CVD
Shock Absorber: Metal
Bumper: Plastic
Motor: 540 35T
Input Voltage: 7.2V—12V
RMP: 12000
Axle Gear Tooth: 38T/15T
Wheelbase: 313mm/ 12.3inch
Length: 435mm/ 17.1inch
Width: 214mm/ 8.43in
Weight: 1200g
Weight (with wheels): 1692g
Package Information:
Package size: 42.7 * 22.4 * 13.8cm / 16.81 * 8.81 * 5.43in
Package weight: 2006g
General box package
Note:
* In order to gain a complete RC car, you need to buy a transmitter, a receiver, a ESC, a servo, a battery, a charger and a car body shell.
Package List(With tires):
1 * 313mm Wheelbase Chassis with Tires
4 * Tires
1 * Front Bumper
1 * Screw Kits
Pris: 990kr
Skicka PM vid intresse!
Namn:	AUSTAR-313mm-Wheelbase-Chassis-Frame-With-540-35T-Brushed-Motor-for-1-10-AXIAL-SCX10-II.jpg_q50.jpg
Visningar:	65
Storlek:	42,8 KB
Id:	71598Klicka på bilden för en större version.
Namn:	AUSTAR.jpg
Visningar:	58
Storlek:	63,9 KB
Id:	71600Klicka på bilden för en större version.
Namn:	IMG_20200909_171514.jpg
Visningar:	59
Storlek:	106,7 KB
Id:	71599Klicka på bilden för en större version.
Namn:	IMG_20200909_171542.jpg
Visningar:	58
Storlek:	137,4 KB
Id:	71601Klicka på bilden för en större version.
Namn:	IMG_20200909_171531.jpg
Visningar:	58
Storlek:	140,4 KB
Id:	71602Klicka på bilden för en större version.
Namn:	IMG_20200909_171501.jpg
Visningar:	57
Storlek:	128,0 KB
