Resultat 1 till 20 av 21
Ämne: Sky Drone FPV: Long Range Digital HD Video FPV Solution
    Thumbs up Sky Drone FPV: Long Range Digital HD Video FPV Solution
    Sky Drone, a Hong Kong based start-up, has developed a revolutionary new way of transferring FPV video. Utilizing 3G and 4G/LTE networks, Sky Drone FPV is the world's first and only full HD Digital FPV video solution for consumers. The Sky Drone FPV groundstation software automatically adapts video transmission frame by frame to the available bandwidth, ensuring minimal latency. With the Sky Drone FPV groundstation app, users can receive real-time HD FPV video straight on their own Smartphone or Tablet.
    Users have the option to connect the Sky Drone FPV hardware to a MAVLink compatible Autopilot Board like 3D Robotics APM. A Head Up Display (HUD) will be rendered on top of the live video stream, providing the pilot with real-time telemetry.
    A unique feature of the Sky Drone FPV is the possibility to take 5 megapixel high quality still images during flight. The images are transferred to the groundstation app while the video keeps running uninterrupted. The Sky Drone FPV is not just limited to aerial vehicles. It can be used on ground vehicles and any other use case where real time video transmission is of benefit.
    With Sky Drone FPV a new era of FPV is here! For more information, please head over to our Indiegogo campaign: http://skydrone.aero/fpv-indiegogo
    We invite you to share your comments and questions either on this forum or via email to info@skydrone.aero.
    Flufs avatar
    jul 2012
    1 580
    Datornörd på heltid
    Mölndals ModellFlyg
    Snubblade precis på den, länge funderat på varför allt är så digitalt, frekvenshoppande, programmerbart och allmänt modernt hightech utom just videolänken.
    Får man bara en vettig responstid på den så är det bara att köra
    Occulus Rift skall ju få 1080p i retail (dev kit som finns ute nu är 720p), och är en tidsfråga innan den går via Sky Drone, whopee. Sedan att den går på USB cam, finns ju rätt justa webcams som går på USB dessutom till bra priser.
    Ser riktigt grymt ut, gillar att länken är krypterad också. Vill ha nu ! :P
    Samtidigt börjar man bli lite orolig att när FPV blir såpass sofistikerat jämfört med dom simpla low-tech sändarna vi använder nu kommer det nog inte dröja länge innan det blir specifika restriktion/lagar om detta. Förhoppningsvis inte.
    Man kan jue ta en radiostyrd bil och ha både bild och styrning på 4G och köra typ en mil bort om man har mycket batteri, helt sjukt grymt.
    Impulzes avatar
    sep 2006
    1 352
    Älvsbyn
    Har kört FPV digitalt för 2 år sedan med Wimax länkar och tyvärr så funkar det inte med en latency på 150-200ms. Även dagens COFDM system lider av för hög latency. Det gick få ner responstiden men det var på bekostnad av bildkvaliten.
    Lägger man på kryptering så lär lagget öka...
    //Matte
    Thanks for the feedback! As a matter of fact, one of our stretch goals is to develop native support for the Oculus Rift! As soon I have more news on it I'll post it here. Keep an eye on our campaign page for the latest developments.
    //Matte
    Impulze, the typical end to end latency of the Sky Drone FPV is < 150ms. Also the Sky Drone FPV adapts the video transmission frame by frame to the available bandwidth, achieving minimal latency in data transmission.
    Fluf, Copterdude & Impulze, thanks a lot for your feedback, we appreciate it! We're happy to hear from you here or via info@skydrone.aero . For more information check out our Indiegogo campaign: http://igg.me/at/fpv/x/4433195
    markusbs avatar
    jun 2009
    1 405
    Eftersom detta går på 4G nätet, kostar det pengar att vara uppkopplad då?
    Vad händer med bilden när saldot på kontantkortet blir 0?
    Hi Markusb,
    It would depend on your data plan for your network and yes the image was stop if the prepaid card runs out if only every network offered unlimited data.
    markusbs avatar
    jun 2009
    1 405
    Kul att ni jobbar med en HD lösning åt oss FPVare. Tyvärr låter det inte riktigt hållbart i mina öron.
    Hög latency, kostnad för uppkoppling osv.
    För busflygning i rent hobbybruk vet i tusan, inte för min del.
    Däremot i proffessionell användning kan det nog sälja bra!
    Är det tekniskt omöjligt att bygga en sändare/mottagare som är fristående från mobilnäten men som ändå klarar den ökande bandbredden?
    Impulzes avatar
    sep 2006
    1 352
    Älvsbyn
    Citat Ursprungligen postat av markusb Visa inlägg
    Somsagt, har testat med Wimax som har bra kapacitet och visst går det få ner latency tiden men på bekostnad av bildkvalite. Vi skulle testa ett COFDM att köra FPV på men leverantören kunde inte tillhandahålla ett system med så pass låg latency, och då pratar vi om grejor som kostar 250 000:- . Är ganska tydligt då man kollar på en tv-sändning och samtidigt kör ljudet från radiosändningen. Personligen ser jag inga större brister i dom analoga system man använder, jag tycker bilden är kanonbra och det är i "realtid" och man spelar in i HD.
    //Matte
    markusb & Impulze, thanks for your comments. If you want to get more information & technical insight in our development process, feel free to have a look at our demo video: http://www.indiegogo.com/projects/sk...fpv?c=activity
    Hey all, we've published real END-TO-END LATENCY shots for our Sky Drone FPV project, showing 170ms and 184ms end-to-end latency with the prototype setup. We will make sure to end up at <150ms at launch! Please take a look at the update yourself here: http://www.indiegogo.com/projects/sk...302?c=activity We've also included how we tested it, so you can reproduce this very same test with your own FPV system and compare.
    Senast redigerat av Ajay den 2013-08-28 klockan 08:35.
    Hey all, we've got some exciting news! We've just been interviewed by Bloomberg's Mia Saini, check out some behind the scenes shots of the interview here: http://www.indiegogo.com/projects/sk...302?c=activity
    I just wanted to share the news that the Sky Drone team has demoed their Sky Drone FPV system with the Oculus VR set. Therefore, the FPV video of a drone/UAV flying in mid air can be distorted in real-time and shown inside an Oculus VR headset. Keep in mind that this is only the beginning of our development process for the Oculus VR - many more features to come (e.g. 3D, Headtracking).
    Watch the Sky Drone FPV + Oculus VR video here: http://www.indiegogo.com/projects/sk...302?c=activity
    P.S.: If we don't reach our funding goal we will still go ahead with Sky Drone FPV. While sticking to our timeline of shipping the Sky Drone FPV sets in December 2013, we will only have a groundstation app for Android at start. Other platforms will be supported later (free of charge). The only way to secure the Early Bird price ($349) of a Sky Drone FPV set, is to purchase the Early Bird perk before this Indiegogo campaign expires. If the funding goal is not reached, Early Bird funders will get discount information to order from our website later. We are 100% committed to our technology and we will prevail.
    There is a little more than 1 day left in our campaign and we would like point out again that we are 100% committed to our technology.
    With only 1 day left in our campaign, there is also only 1 day left to secure the Early Bird price for a Sky Drone FPV set.
    Sky Drone FPV campaign: http://www.skydrone.aero/fpv-indiegogo
    Impulzes avatar
    sep 2006
    1 352
    Älvsbyn
    Serious? Sounds more and more like scam.
    //Matte
    Varför bryr dom sig om att slänga på AES-256 om allt går via 3G/4G? känns ju inte riktigt relevant iaf för min flygning att behöva skydda sig för insyn från myndigheter...
    Sedan är ju frågan hur dom tänkt få ner latency i 3G nätet, låter mest som hittepå detta.
    Driver Svenska FPV forumet http://fpv.nu
    Trex 700 Vbar, Trex 500BeastX,
    QAV500 Openpilot Revolution , T8FGS
    Citat Ursprungligen postat av dezent Visa inlägg
    Hi dezent, the AES-256 encryption is very handy when you intend to use the Sky Drone FPV for surveillance purposes.
    //Matte
    Hi Matte, we can assure you that this isn't a scam. We're working very hard to make the Sky Drone FPV reality!
    Hey all, we want to let you know that our Pre-Order page is now online! Go to http://www.skydrone.aero/ to pre-order the Sky Drone FPV today!
    Hey all, check it out, we've posted anew demo video on YouTube. It shows off the Sky Drone FPV beingcontrolled via head-tracking using the Oculus VR/Rift:https://www.youtube.com/watch?v=arvLm4DnMg8 Let us know what you think!
    Impulzes avatar
    sep 2006
    1 352
    Älvsbyn
    Headtracking is an old invention. Why do you want a lean function of the HT? Thats the most akward function i ever seen for FPV.
    //Matte
    Flufs avatar
    jul 2012
    1 580
    Datornörd på heltid
    Mölndals ModellFlyg
    //Matte
    The headtracking ins't the interesting part here, it's the Occulus Rift support including it's headtrack
