Resultat 1 till 6 av 6
Ämne: Nya DL killern
    Siguns avatar
    3 958
    Dackeflyers
    Smile Nya DL killern
    http://www.hobbycity.com/hobbycity/s...idProduct=8859
    __________________________________________________ ____________
    HP-50
    Turnigy HP50 50cc Gas Engine 5.5HP
    Earmarked in China as the DL50-Killer. The Turnigy HP-50 has shamelessly borrowed porting and head design from the DL and combined it with a CNC machined billet alloy crank-case to produce a powerful, lightweight and reliable engine.
    HP-50 Spec.
    CDI Electronic Ignition with auto advance
    Walbro Carburettor
    Performance: 5.5hp
    RPM: 1200-10000rpm
    Idle: 1200rpm
    Thrust: 13.6kg @ 100mtr / 11.5kg @ 1800mtr (Above sea level)
    Suggested prop: 20x8-10 ~ 22x8-10 or more!
    Spark Plug: CM-6
    Bore/Stroke: 43 x 35mm
    Compression: 7.5:1
    Weight: 1380g
    Fuel: 2 Stroke oil/fuel mix (30:1 - 45:1)
    Walbro membrane pump carburetor with manual choke!
    Automatic advancing electronic ignition!
    For more power, use unleaded fuel with an octane rating of 98.
    $239.95
    Per Ps avatar
    jun 2007
    1 263
    Robotprogrammerare
    Stranda Modellflygklubb
    Du menar nya DA-killern va? Nu kan vi väl börja snacka kopia av DA-50....
    Våga vägra Powerbox!
    Nyroths avatar
    715
    Modellflyg nostalgiker
    No body kills DA king!!
    mulders avatar
    nov 2006
    1 033
    DA is real Power, Da is the best fuck the rest. /Mulder
    Flyger: JET
    Bygger: I Composite
    Motor: Turbin
    Radio: Futaba
    JET SKÅNE
    wesses avatar
    5 871
    Nykter Alkoholist
    ¤Sunday Team¤
    Citat Ursprungligen postat av Nyroth Visa inlägg
    Get high with hovering
    not drugs
    wesses avatar
    5 871
    Nykter Alkoholist
    ¤Sunday Team¤
    Citat Ursprungligen postat av mulder Visa inlägg
    not drugs
  1. Dl 50
    Av göran1 i forum Allmänt och Tips
    Senaste inlägg: 2017-07-01, 05:46
  2. Ljuddämpare DA/DL
    Av KenPro i forum Bensinmodeller
    Senaste inlägg: 2009-05-25, 22:16
  3. Nya DL motorer på gång
    Av Sigun i forum Förbränningsmotorer
    Senaste inlägg: 2009-05-17, 19:43
  4. Dl-222!!!!!!!!!!!!!!
    Av anders e i forum Förbränningsmotorer
    Senaste inlägg: 2009-02-27, 07:29
  5. dl 50
    Av klarre i forum Bensinmodeller
    Senaste inlägg: 2008-06-05, 21:57
