Resultat 1 till 5 av 5
Ämne: dji googels för mavic
    Standard dji googels för mavic
    Någon som hunnit testa dessa ännu?
    Dom verkar ju ganska lovande i dom tester jag sett.
    Beställde ett par hoppas dom kommer inom 1-2 dagar.
    Goggles om jag får be. ;-) www.google.com
    Jag vart också lite nyfiken på dem... kan man ha dem istället för tex FatSharks?
    https://www.dji.com/dji-goggles
    Googles skall det så klart vara
    Verkar som det är klart bäst med en Mavic ansluten. Verkar svårt å köra dom som en ersättare till FatSharks. Lite för krångligt å hålla på med analog till digital converters. mm
    The DJI Goggles have 3 input methods, depending on what craft you have there are the below options
    Wireless OCUSYNC - Mavic Pro Only
    The DJI Goggles have built in Ocusync receiver and connect to the Mavic wirelessly completely separate from the RC, you can connect unto 4 devices at the same time.
    Connection combinations wirelessly are :
    1: One DJI Goggles + one Mavic Pro Remote Controller
    2. Two DJI Goggles + two Mavic Pro remote controllers
    3. One DJI Goggles + two Mavic Pro remote controllers
    USB
    The DJI Goggles can be connected to the Phantom 4, Phantom 4 Pro, Phantom 4 Advanced, and Inspire 2*** via Micro USB.
    When Using USB connection head tracking is available on all models listed above as is FOCUS controls on the Phantom 4 Advance, Pro and Inspire 2***.
    *** There is current a little confusion if the Inspire 2 does support head tracking over USB, the manual states it both does and does not, My belief is it will at release or shortly after but I will amend this to confirm then we actually know.
    HDMI
    The Goggles can be connected older DJI aircraft such as the Phantom 3 or Inspire 1 via HDMI, You can also connect to Inspire 2 and Phantom 4 via HDMI however head tracking will not be available.
    Any other device with a HDMI output can also be connected to the DJI goggles this way as well as lowing you to connect it to many 3rd party devices and drones.
    Haha, nu såg jag att du först skrev googels. Sen rättade du till googles. Jag menar fortfarande goggles. ;-)
    HDMI<->RCA/Video-konverter är inget special, har en sån till och med som suttit i en hexacopter med Sony Nex-kamera. Men det är iofs fel väg... Hoppeligen så har nån säkert snart använt DJI Goggles till nåt annat än DJI. =)
    Hur som helst... har du fått dem? Testat? Nöjd?
    haha det va fan va det skall va besväligt å få till goggles
    Inte fått dom ännu. Verkar som dom inte skickas förrens i slutet på denna månaden.
    Dock så är min kenisiska fortfarande rätt begränsad så jag kan ha läst fel
