Jag har ett 130 A som jag inte får gasen att funka som den ska startar inte för än på halv gas vad gör jag för fel
Hobbywing Fly Fun V5 130 A
Har du gjort throttel kalibreringen?
ESC/Radio Calibration
Turn on the transmitter and move the throttle stick to the top position.
Connect a battery to the ESC; the motor will sound “♪123” to indicate the ESC is normally powered on.
Then the motor will beep two short beeps to indicate the maximum throttle endpoint is accepted.
Move the throttle stick to the bottom position within 5 seconds after the two short beeps, the minimum throttle position will be accepted 1 second later.
The motor will beep “Number” beeps to indicate the number of LiPo cells you have plugged in.
The motor will beep a long beep to indicate the calibration is complete.Bill Hempel YAK55 120cc 103''
Skywing Slick 120cc 104”
Pilot RC Decathlon 100cc 122”
3DHS Edge 540 V2 61cc 92''
OMP Edge 540 35cc 74''
SAB Goblin 420
SAB Goblin 700C
SAB Black Nitro 700
