(ursäkta engelskan, postade på rc groups oxå...)
I am trying to equip my SS for longer flight times.
I have bought the following items to accomplish this:
1. Hobbywing Pentium 40A ESC
2. Motor: XYH35-30 1100kv 15A Brushless Outrunner (http://www.giantshark.co.uk/xyh3530-...-p-402740.html). I also have the 1400kv version to use if the 1100 should fail.
3. 8x4 Prop / 8x6 Prop / 7x6 Prop
4. Gens Ace 3300 25C 3S Lipo Battery (I also have a couple of 2200 mah to use if too heavy)
What do you guys think of this setup?
What Prop do you suggest?
I am going to have to solder extension cords for the motor leads using 3,5mm bullet connectors, any comments on that (except for keeping them as short as possible I guess).
I use the CNC motor mount. Is this the correct mounting of the motor?
Apart from checking the COG after everything has been installed, is there anything else I should do?
