Jag har två Futaba 10J och en trainer-kabel och skall köra med min son. Jag lyckas dock inte tolka manualen. Man kan välja mellan 4 moder (per kanal, alltså alla kanaler kan individuellt sättas en av 4 moder enligt nedan):
Vilken mode är lämplig och hur fungerar den?
/ Tack på förhand, Mikael
FNC mode: The channel set to this mode can be controlled by the student using the mixing set at the instructor’ s transmitter. *Student settings are returned to their initial value in advance. Next, reverse function makes all channels normal.
MIX mode: The channel set to this mode is controlled by mixing the instructor and student signals. Correction rudder is applied by the instructor. When this mode is selected, the student’ s rate is reduced to prevent servo overthrow. The student’ s rate can also be set. *Student settings are returned to their initial value in advance. Next, reverse function makes all channels normal.
NOR mode: The channel set to this mode is controlled by signals from the student’ s transmitter. (The instructor and student settings must be the same.)
OFF mode: The channel set to this mode cannot be controlled by the student. It can only be controlled by the instructor
