Ny på FPV!
  • acessyd
    • 10
    Ny på FPV!
    Hej !
    Har surfat runt en hel del och blir mer och mer kluven vad jag ska köpa.
    Hittade detta kit som har allt, men är det något att ha ? Rätt så dyrt också.
    FPV & UAV
    869 - 915MHZ 869 - 915MHZ
    ALCANCE 18 - 72Km SCOPE 18 - 72km
    PROFESIONAL PROFESSIONAL
    The kit contains the necessary elements for flights FPV or UAV from 18Km to 72Km. This kit takes the known OSD644DMDG v2.51 with HUD's F16 plus barometric altimeter to 4000m. And also the BootADMD Loader software (firmware) and setup (SETUP) OSD644DMDG via USB.
    Included in the kit a 2650mAh battery Life for the station.
    The servos included are appropriate for an aircraft like the Easy Glider Pro or Star of the firm Multiplex.
    Patch Antenna 869-915MHz, 9dBi SMP-918-9, to ensure maximum reach of the remote control.
    Kit Audio / Video 2.4GHz to display its FPV to 25Km (camera, 17dBi patch antenna, connectors, etc.)..
    Module incorporates Gluevideo_L2B easier installation kit Audio / Video.
    It incorporates a DCDC24/5RC V2 to increase the efficiency of the battery.
    A quality video glasses complete the kit.
    The new version 2.51 LRS.
    Free IR Sensor also.
    Caracteristicas: Features:
    Long range: 72km, @ 95%.Maximum: 112km
    - Safety, Quality and 10 hours of battery Issuer
    - Bidirectional, Alarms and Telemetry.
    - Audible alarms: low coverage, Fail Safe.
    - Expandable via RCBUS.
    : Content:
    Sender Box:
    - Transmitter WFT09
    - Switch ON / OF
    - 4 servos TG9 or HXT900 (Depending Stock)
    - 2650mAh Battery Life
    - Cable Charge
    - Correa Emisora - Sending mail
    - Cable Professor Student
    - Simulator Cable Connection (JR)
    - Manual on CD-ROM Instructions
    PACKLRSP1 Box-0001:
    - 1 RCRX11PV2 . Receiver Blue's long-range 18-72km and 9 channels.
    - 1 TX11MFLRS-500 . Blue Transmitter 500mw long range bidirectional.
    - 1 OSD644DMDG.On Screen Display Graphic + GPS.
    - 2 Omni-directional 5dBi antenna.
    - 1. Alarmas Acusticas. Audible alarm.
    - 1 Altimeter Analog 0-4000m.
    Cargador USB firmware y setup Firmware and setup USB Charger
    - 1 button.
    . DCDC24V to 5V/2A Converter for RC.
    - 1 Manual de instrucciones del LRS en un DVD. - 1 Instruction Manual LRS on DVD.
    Box SMP918-9:
    - SMP918-9. Antenna Pacth 9dBi.
    KITAVFPVSTP Box:
    - Camera SN-494CN / 494CN SN-B or P / Pinhole (Depending Stock)
    - Special BL-610T.Transmisor/Receptor FPV 2.4Ghz 1000MW
    - 1000mAh or 1300mAh battery (Depending Stock)
    - It facilitates the wiring of FPV video system in seconds.
    - Hose adapter antenna-receiver video (LATSMAHN1)
    - Battery Adapter Cable
    - Antenna 2.4Ghz 17dBi planar patch (ANTPLA24G17DB)
    Box Video Glasses:
    - EVG920V. - EVG920V. Video Glasses.
    For more information click here http://www.dmd.es/lrs.htm http://www.dmd.es/lrs.htm
    Mikael
  • MrOvanhill
    • jan 2008
    • 468
    Hmm... min omedelbara reaktion är att man nog ska hålla sig borta från 900MHz eftersom vi har GSM på det bandet. Mycket störningar där alltså. Det är nog ganska fullt där i trakten.
    Glasögonen är ok. Jag har såna och är inte missnöjd i alla fall.
    Resten.. vet inte. Nån annan får kommentera det.
    Mvh, Thomas
    Modellflyg ur ett kretsloppsperspektiv
    Byggsats - Flygplan - Byggsats igen...
      • 5249
      Allt i kittet är olagligt att använda i Sverige så glöm det helt och hållet. Berätta lite mer vad du vill göra och vad du har tänkt dig för prisklass?
      • acessyd
        • 10
        Vad jag vill göra är kunna flyga på någorlunda distanser och ändå har säker RC-Link och Video-Link.
        Och vad jag har läst så desto lägre frekvens ju bättre mottagning om man flyger över lite terräng.
        Skulle kunna tänka mig RC-link på 400mhz bandet och Video-Link på 2,4ghz.
        Pris klass på ett komplett kitt, kanske runt 10-12000:-.
        Så borde jag få bra saker.
        Tacksam för hjälp med att sätta ihop ett bra kit.
        mvh Mikael G
        • StarvinMarvin
          • 315
          Du måste nog väga mellan Lagligt o distans. För köper du ett tex 5.8ghz system som inte är för starkt så behöver du bara flyga bakom ett löv eller två så tappar du bilden (enligt vad jag hört om 5.8)
          Tror det bästa är att köpa 1.2-1.3ghz på ca 1000mw för det ska va lagligt inbillar jag mig o du får bra räckvidd också.. sen klarar du dig bra på en vanlig 2.4ghz radio.. jag har ca 2km och då har videolänken dött för länge sen..
          Man lär sig nått varje krash... :stupido2:
          • Jode
            • 290
            Räckvidden handlar mycket om bra och rätt antenner.
            Det får man forska lite själv i.
            RcGroups är ett tips. Där finns all info om all RC och FPV.
            • Impulze
              • 1347
              dmd använder sig av ism bandet för sin rc-länk. Detta band är undantaget från tillståndsplikt. Det tråkiga med DMD är supporten, kan ta dagar innan man hör av dom och sen så fixar dom inte engelska så bra heller. För mig så var det system lite för invecklat och jag har inte tid att mecka allt för mycket med en massa inställningar.
              //Matte
