Rssi?
    Rssi?
    Håller på löder lite kablar till en TBS Core till min Caipirinha och fastnade lite på RSSI... är det nåt som endast finns på EzUHF-grejer? I så fall kan jag ju skippa den kabeln iaf. =)
    Står så här:
    Relative Signal Strength Indicator (RSSI)
    RSSI is the signal strength of your R/C signal that arrives at the plane. All major FPV R/C system vendors
    support either analog or digital (PWM) RSSI. The TBS OSD has a RSSI port where you can connect and
    then calibrate the RSSI output. RSSI is shown with a percentage number ranging from 0 to 100. If it is
    calibrated correctly, 0% means no signal, 100% means full signal. Connecting RSSI is straight forward.
    Simply wire the RSSI output of your receiver to the appropriate port on the TBS CORE.
    Refer to the manual of your R/C system to find out where the RSSI comes from. Configuration
    instructions of analog RSSI are available in the next chapter.
    The EzUHF is the first FPV UHF system that supports digital RSSI. To feed that information to the TBS
    CORE, connect your EzUHF receiver to the ImmersionRC Tools and select a channel on the “RSSI Needle”
    setting. That channel needs to be routed to the RSSI input. For configuration instructions please refer to
    the next chapter.
    • 5250
    TBS core stödjer bara EZ-Uhf eller vanlig analog signal 0-5v, så det beror ju helt på vad du har för mottagare och vad den har för möjligheter.
    • neu
      • aug 2012
      • 1047
      Inte bara EzUhf den stödjer alla mottagare med digital rssi som Openlrs, frsky och en hög andra. Den stödjer även analog Rssi.
        Futaba R617FS sitter det i caipen nu...
        • neu
          • aug 2012
          • 1047
