-Senaste aktiviteten
-Senaste besöket
Det låter intressant så jag kolla hans plan vad han har för motor ??och om det verkar var el-motor ser ut där ???
MVH Steve
Excell 60 2 St
Heim 10 CC skala Hughes 500 E
Concept SR
Modeltech Cap 21 2 st
Wonder 2 St
skaffa:Ace Ultimate, Edge 540
Blohm und Voss Bv.138 C-1
Date: 1941
Description: Trimotor, straight-wing flying boat
Mission: Reconnaissance
Manufacturer: Blohm und Voss Schiffswerft Abteilung Flugzeugbau
Nation: Germany
Engine(s): Three 880-hp Junkers Jumo 205 liquid-cooled 6-cylinder in-lines
Versions:
Speed: 177 mph (285 km/h)
Range/Endurance: 2,669 miles (4,295 km)
Ceiling: 16,400 ft. (5,000 m)
Armament: 2 machine guns; two 20mm cannons; 661 lb. (300 kg) bomb payload
Crew: 5
Wingspan: 88 ft. 4 in. (26.92 m)
Length: 65 ft. 1 in. (19.65 m)
Weight: 31,967 lbs. (14,500 kg)
Notes: The Bv.138 flying boat worked closely with German submarines as a
reconnaissance aircraft.
/Anders
"Some data on the Modell BV-138:
Type: BV138-C1
Built: 2006
Span: 299 cm / 9.8ft
Length: 221 cm / 7.25ft
Hight: 72cm / 2.36ft
Wing area: 1,321 qm / 14.22 sqft
Material: Balsa Max. el. power: 2,5 kW bei 15V (4S)
Endurance: 22min
The fuselage of the model contains a 5 litre water tank.
When in the water, the tank is flooded to achieve a scale water line.
The ballast water is bailed on take off"
