True 640x480 8ch 2.4/5.8Ghz Dual Rx w/ HeadTrack Video Goggles
Add a totally new dimention to your R/C car, plane or heli! These video goggles give you a high resolution display. Its just like you were flying the plane/heli yourself!
And because these goggles are 5.8Ghz ready, they wont interfere with your current 2.4Ghz system!
These 640x480 resolution 2.4/5.8Ghz Dual Receiver 8ch video goggles come with a true full colour micro LCD panel and a silicon rubber shield for blocking sunlight, giving the user a rich 80 inch virtual screen display perfect for high-end FPV flight.
A compact and light-weight design, Adjustable volume, Brightness and Contrast plus they can be powered by the Tx and include full anti-drift head-tracking via your transmitter!
Powered by your TX or an 8~13V input these goggles are equipped with the dual Audio/Video receiver module, just use the appropriate antenna provided with the kit and set the frequency from 2.4 to 5.8Ghz in the OSD (On Screen Display) menu and you will be ready to receive the video from your FPV transmitter.
These goggles are perfect for a screen overlay Data Expander (like eagletree) due to its large 640x480 size high resolution screen.
Spec.
Display resolution: VGA 640x480 RGB, 922k pixels
Field of view: 32 degree
Virtual image size: 80 inches
Frequency: 2.4GHz / 5.8GHz (selectable)
Audio & Video: input/output
Input voltage: 8~13V
Included.
1 x 640x480 8ch 2.4/5.8Ghz True Color Video Goggles
1 x Data cable (External Power & Headtracking)
1 x Power Cable for Lipo battery
1 x Antenna for 2.4GHz
1 x Antenna for 5.8GHz
